Knowledge Base Article
Why does the Intel® P-Tile Avalon® Memory Mapped IP for PCI Express* 4.0x4 Root Port design example reports an error during compilation?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 20.1 or earlier, the Intel® P-Tile Avalon® Memory Mapped IP for PCI Express* 4.0x4 Root Port design example reports an error during compilation.
Error(21410): Verilog HDL error at s10_rp_avmm_master_hwtcl.v(130): event control statement inside subprogram is not supported for synthesis
Resolution
To work around this, it is necessary to generate the simulation and synthesis file separately and re-compile the design example.
This problem is fixed starting with the Intel® Quartus® Prime Pro/Standard Edition Software version 22.4.
Updated 11 months ago
Version 3.0
