Knowledge Base Article
Why does the GTS SDI II IP Multi-rate Dual Simplex Serial Loopback Design Example fail to achieve lock on Agilex® 5 FPGA E-Series Premium Development Kit at 12G data rate?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3, you may observe the rx_align, rx_frame and rx_trs signals fail to achieve lock when running the GTS SDI II IP Multi-rate Serial Loopback Design Example on Agilex® 5 FPGA E-Series Modular Development Kit at 12G data rate.
Resolution
This problem is fixed beginning with the Quartus Prime Pro Edition Software version 26.1 .
Updated 3 months ago
Version 9.0No CommentsBe the first to comment
