Knowledge Base Article
Why does the GTS JESD204B IP and GTS JESD204C IP with HVIO PLL clocking mode enabled failed the Quartus® Fitter compilation?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3.1, you may observe the following error during Fitter compilation:
"One or more blocks are configured incorrectly and will not have the desired functionality. --bcm instance name: hvio_1_1"
This error occurs because Quartus® automatically assigns the hvio_refclk* port to an illegal location during placement.
Resolution
To work around this problem, you can manually assign the hvio_refclk* port to a HVIO bank.
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition software.
Updated 3 months ago
Version 3.0
