Knowledge Base Article
Why does the GTS AXI Streaming IP for PCI Express* PIO design example fail during hardware testing?
Description
Due to a problem in the GTS AXI Streaming IP for PCI Express* PIO design example, you might encounter a failed PIO Link test when using the AMD platform as the host.
When performing the Link test - 100 writes and reads, the system may consistently return a read value of 0xFFFFFFFF, regardless of the target read address.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
