Knowledge Base Article
Why does the F-Tile Triple-Speed Ethernet IP with core variation 10/100/1000 Ethernet MAC with 1000BASE-X/SGMII 2XTBI PCS and Embedded PMA Signals (F-Tile) drop packets?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1.1, you may see packets dropped when the F-Tile Triple-Speed Ethernet IP is configured to 10/100/1000 Ethernet MAC with 1000BASE-X/SGMII 2XTBI PCS and Embedded PMA Signals (F-Tile) variant.
This is because the IP default settings for flux_mode are set as "FLUX_MODE_FLUX_MODE_SNIFFER" and rx_adaptation_mode is set as "RX_ADAPTATION_MODE_FLUX_ADAPTATION".
Since the F-Tile Triple-Speed Ethernet IP line rate is 1.25 Gbps, the recommended flux_mode needs to be set as "FLUX_MODE_FLUX_MODE_BYPASS" and rx_adaptation_mode needs to be set as "RX_ADAPTATION_MODE_MANUAL_ADAPTATION".
Resolution
To work around the above problem, you can add the following assignment to the project setting .qsf file:
set_instance_assignment -name HSSI_PARAMETER "flux_mode=FLUX_MODE_FLUX_MODE_BYPASS" -to <RX_SERIAL_PIN> -entity <TOP_LEVEL_NAME>
set_instance_assignment -name HSSI_PARAMETER "rx_adaptation_mode=RX_ADAPTATION_MODE_MANUAL_ADAPTATION" -to <RX_SERIAL_PIN> -entity <TOP_LEVEL_NAME>
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.
