Knowledge Base Article
Why does the F-Tile PMA/FEC Direct PHY Intel® FPGA IP with PMA type set FGT, Enable RS-FEC disabled, Datapath clocking mode set PMA, PMA width set 32 and Enable TX FGT PLL fractional mode enabled fail to pass Quartus Support Logic Generation?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3, the F-Tile PMA/FEC Direct PHY IP variant with the “PMA type” parameter set to “FGT”, the “Enable RS-FEC” parameter disabled, the “Datapath clocking mode” set to “PMA”, the “PMA width” parameter set to “32”, and the “Enable TX FGT PLL fractional mode” parameter enabled will fail to pass Quartus Support Logic Generation.
The errors that are generated will contain a string that is similar to the one shown below:
Error (21843): user.bb_f_ux_tx[0] -> u0|directphy_f_0|dphy_hip_inst|persystem[0].perxcvr[0].fgt.tx_ux.x_bb_f_ux_tx
Error (21843): is_used == TRUE
Error (21843): location == UX15
Error (21843): synth_lc_slow_f_out_hz == 8000000000
Error (21843): synth_lc_slow_f_ref_hz == 182000000
Error (21843): synth_lc_slow_f_rx_postdiv_hz == 320000000
Error (21843): synth_lc_slow_f_vco_hz == 8000000000
Error (21843): synth_lc_slow_rx_postdiv_counter == 50
Error (21843): tx_tuning_hint == TX_TUNING_HINT_DISABLED
Resolution
To work around this problem, you must add a QSF assignment to your project that overrides the setting for the “synth_lc_slow_rx_post_counter.”
Below is an example of the required assignment. Note that the hierarchy will be specific to your design.
set_instance_assignment -name HSSI_PARAMETER "synth_lc_slow_rx_postdiv_counter=25" -to u0|directphy_f_0|dphy_hip_inst|persystem[0].perxcvr[0].fgt.tx_ux.x_bb_f_ux_tx
This problem was fixed in version 24.3.1 of the Quartus® Prime Pro Edition Software.
