Knowledge Base Article
Why does the F-Tile PMA/FEC Direct PHY FPGA IP variant with the “RS-FEC Mode” parameter is set to either “FlexO RS(544,514) or “FlexO RS(528,514)” fail to simulate properly?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3, the F-Tile PMA/FEC Direct PHY IP variant with the “RS-FEC Mode” parameter set to either “FlexO RS(544,514)" or "FlexO RS(528,514)” will fail to simulate correctly.
In simulation, the “rsfec_sf”, “rsfecstatus_rx_not_align”, and “rsfec_status_rx_not_locked” ports of the IP will always be 1’b1.
This problem does not affect the operation of the IP in hardware.
Resolution
To workaround this problem in Quartus®  Prime Pro Edition Software version 24.3, add the following compile option to the simulation script for your selected simulator:
+define+ SKIP_SIM_MODEL_LOG2_MRK
For example, if using the QuestaSim* simulator, add the following line to the simulation script:
set USER_DEFINED_VERILOG_COMPILE_OPTIONS "+define+ SKIP_SIM_MODEL_LOG2_MRK"
Updated 5 months ago
Version 4.0
