Knowledge Base Article
Why does the F-Tile JESD204C IP Parameter Details window show that the Converters per device (M) parameter supported range is from 1 to 256 in version 25.1 of the Quartus® Prime Pro Edition software?
Description
The supported range of the M parameter in the F-Tile JESD204C IP Parameter Details window is shown as 1–256; however, Section 6 of the F-Tile JESD204C IP User Guide specifies the correct range as 1–128. The range displayed in the Parameter Details window is a known bug—please refer to the User Guide for accurate information.
6. F-Tile JESD204C IP Parameters
Resolution
The M parameter in F-Tile JESD204C IP Parameter Editor has been fixed starting with Quartus® Prime Pro Edition Software version 25.3.
Updated 4 months ago
Version 4.0No CommentsBe the first to comment
