Knowledge Base Article
Why does the F-Tile JESD204C Altera® IP Design Example fail to compile when migrated from a previous version of the Quartus® Prime Pro Edition Software to version 24.3?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3, the F-Tile JESD204C Altera® IP Design Example will fail to compile when migrated from any previous version of the Quartus® Prime Pro Edition Software to version 24.3.
Resolution
Follow the instructions below to work around this problem in the Quartus® Prime Pro Edition Software version 24.3 by manually editing the module to remove the unused port.
  1. In the Files tab under Project Navigator window, locate the ed_control IP file (…rtl/<data_path>/ip/j204c_f_<data path>_ss/j204c_f_<data path>_ss_ed_control.ip) .
  2. Expand the directory and find the target module (…rtl/<data_path>/ip/j204c_f_<data path>_ss/j204c_f_<data path>_ss_ed_control/synth/j204c_f_<data path>_ss_ed_control.v)
  3. Comment out the all “csr_tst_ctl_tst_control_error_inject” ports.
For example:
//  output wire csr_tst_ctl_tst_control_error_inject
The problem has been fixed starting with Quartus® Prime Pro Edition software version 24.3.1.
Updated 3 months ago
Version 6.0
