Knowledge Base Article
Why does the F-Tile JESD204B Agilex™ 7 FPGA IP Design Example Generation fail when the data rate is between 16.3 Gbps and 17.1 Gbps?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 22.4 and earlier, you may see the F-Tile JESD204B Agilex™ 7 FPGA IP Design Example Generation failure when the data rate is between 16.3 Gbps and 17.1 Gbps for all PMA speed grade devices.
The cause of this problem is an internal phase-locked loop (PLL) is being selected to the incorrect mode.
Resolution
There is no workaround.
Updated 2 months ago
Version 2.0
