Knowledge Base Article
Why does the F-Tile Ethernet Dynamic Reconfiguration (DR) design not work when one of the profiles has PTP enabled?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 23.3, the F-Tile Ethernet designs using Dynamic Reconfiguration with PTP enabled on some of the profiles will fail to work correctly if the startup profile of the design does not have PTP enabled.
Resolution
To work around this problem, ensure that the startup profile of your dynamically reconfigurable Ethernet design has PTP enabled if any of the profiles have PTP enabled.
Updated 3 months ago
Version 6.0No CommentsBe the first to comment
