Knowledge Base Article
Why does the Even-Odd-Jitter(EOJ) of the FHT transmitter fail compliance specification with the ethernet line rate above 25.78125 Gbps?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.3, you may see the EOJ of the FHT transmitter fail compliance specification with the Ethernet line rate above 25.78125 Gbps.
The below FHT variants are failing.
  • FHT NRZ 29 Gbps
  • FHT PAM4 116 Gbps
  • FHT NRZ 28 Gbps
  • FHT PAM4 106.25 Gbps
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition software version 24.3.
Updated 11 months ago
Version 3.0
