Knowledge Base Article
Why does the DisplayPort IP design example fail to generate a programming file when using the Quartus® Prime Pro Edition Software v19.1?
Description
Due to a problem in the Quartus® Prime Pro Edition Software v19.1, designs that use the Nios® II/e processor core without a valid Nios® II processor license will fail to generate programming files even though the design compilation is successful.
The DisplayPort IP design example uses the Nios II/e processor core. Hence, it will be impacted by this problem.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software v19.1, install the patch 0.02 below and regenerate the DisplayPort IP design example:
This problem is fixed starting with the Quartus Prime Pro Edition Software v19.2.
Updated 4 months ago
Version 5.0
