Knowledge Base Article
Why does the design example generated by the 25G Ethernet Intel® Arria® 10 FPGA IP not work on the Intel® Arria® 10 GX Transceiver Signal Integrity Development Kit?
Description
When using the 25G Ethernet Intel® Arria® 10 FPGA IP the example design section incorrectly shows the Intel® Arria® 10 GX Transceiver Signal Integrity Development Kit as an available option in the Target Development Kit:Select board parameter. This is mistake as the generated example design targets the Intel® Arria® 10 GT family only.
The Intel® Arria® 10 GX family does not supprot the required 25G transceivers.
Resolution
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition software version 20.4.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
