Knowledge Base Article
Why does the calculated VCO frequency of TX FGT PLL fractional mode in the IP Catalog GUI mismatch with the VCO frequency formula in the F-Tile Architecture and PMA and FEC Direct PHY IP User Guide?
Description
Due to incorrect formula in the F-Tile Architecture and PMA and FEC Direct PHY IP User Guide (UG20315), you may see the calculated VCO frequency of TX FGT PLL fractional mode in the IP Catalog GUI when Enable TX FGT PLL fractional mode option enabled mismatch the VCO frequency calculated by the formula in F-Tile Architecture and PMA and FEC Direct PHY IP User Guide with M,K,N,L and reference clock frequency parameters which reported in system messages window.
The correct formula is the following:
VCO frequency = (M + k/2^22) * refclk frequency (MHz) * mul_div / N.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 24.1.
Updated 3 months ago
Version 5.0
