Knowledge Base Article
Why does the BAM (Bursting Avalon‑MM Master) module of the GTS AXI Multichannel DMA IP for PCI Express* fail to generate Completion TLPs in a PCIe Root Port implementation?
Description
Due to a problem in Quartus® Prime Pro Edition software version 26.1, the BAM in the AXI Multichannel DMA IP for PCI Express* may fail to return Completion TLPs in simulation once the completion buffer reaches a specific threshold.
In hardware, this problem may manifest as data corruption when the outstanding completion data reaches the same threshold.
Resolution
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 6 months ago
