Knowledge Base Article
Why does the Arria® 10 HDMI FPGA IP Design Example polarity inversion setting not affect the generated RTL?
Description
Due to a problem in the Arria® 10 FPGA HDMI FPGA IP Design Example when using the Quartus® Prime Pro Edition Software version 23.4, the polarity inversion setting for the HDMI RX PHY does not affect the generated RTL.
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition Software version 23.4.
Download and install Patch 0.63 below.
Step to enable polarity inversion:
  1. Apply patch
  2. Generate design example
  3. Edit ./rtl/ip/nios/intel_hdmi_rx_phy.ip in the IP GUI and set parameters based on user requirement
  4. regenerate the IP by clicking "generate HDL"
  5. Compile the design
  6. Run in the hardware
This problem is fixed beginning with version 25.1 of the Quartus® Prime Pro Edition Software.
Updated 8 months ago
Version 5.0
