Knowledge Base Article
Why does the Agilex®3 FPGA and Agilex® 5 FPGA Triple-Speed Ethernet IP Design Example, when configured with IEEE 1588v2, fail during simulation using Xcelium* and Riviera*-PRO simulators in Quartus® Prime Pro Edition Software version 25.1.1?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1.1, the Agilex® 3 FPGA and Agilex® 5 FPGA Triple-Speed Ethernet IP Design Example, when configured with IEEE 1588v2, may fail during simulation of the design example testbench.
The following behaviors may be observed:
  • Riviera*-PRO: Simulation may hang or display "Error: Accuracy criteria not met".
  • Xcelium*: Simulation may pass, but accuracy criteria will not be met, leading to incorrect results.
Resolution
There is no workaround to this problem in the Quartus® Prime Pro Edition Software Version 25.1.1.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.
Updated 3 months ago
Version 7.0
