Knowledge Base Article
Why does the Agilex® 5 DisplayPort SST TX-Only example design fail to generate when AXIS-VVP Full is enabled?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.3 and earlier, you might see the following example design generation errors when generating the Agilex® 5 DisplayPort SST TX-Only example design with AXIS-VVP Full enabled.
error: 'VVP_TPG_BASE' undeclared (first use in this function)
Error: Failed to generate example design example_design to: <example_design_path>
Resolution
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition Software.
Updated 1 month ago
