Knowledge Base Article
Why does the Active Serial (x1 and x4) configuration of Intel® Arria® 10 or Intel® Cyclone® 10 GX devices fail after a power cycle when using Macronix flash devices?
Description
When using the Intel® Quartus® Prime Software version 18.1 for the programming of  Macronix flash devices, you will observe a successful programming sequence, but you may observe an Active Serial (x1 and x4) configuration failure after a power cycle, with Intel® Arria® 10 or Intel® Cyclone® 10 GX devices.
Resolution
To work around this problem, check the “Disable EPCS/EPCQ ID check” option in the 'Advanced Options' of the 'Convert Programming File' tool.  This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 19.1.
Updated 11 months ago
Version 3.0
