Knowledge Base Article
Why does system hang when device operates with R-Tile Multi Channel DMA IP for PCI Express* ?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.4 and earlier, you might observe that the host reports a completion timeout error and system hangs when running DMA.
Resolution
To work around this problem, directly disable MCTP option in BIOS and reboot the system.
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
