Knowledge Base Article
Why does Support-Logic Generation report an error when a design containing F-Tile JESD204C IP is configured for a line rate of 25781.25 Mbps?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 26.1, Support-Logic Generation may report an error for a design that contains F-Tile JESD204C IP and is configured for a line rate of 25781.25 Mbps.
Resolution
A patch is available to fix this problem for the Quartus Prime Pro Edition software version 26.1. Download and install patch 0.48 from below.
- Patch 0.48 for Windows(.exe)
- Patch 0.48 for Linux(.run)
- Readme for patch 0.48(.txt)
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 2 hours ago
Version 3.0No CommentsBe the first to comment
