Knowledge Base Article
Why does Questa* license fail to install in the Quartus® Prime Lite Edition Software version 24.1?
Description
This problem is due to user setup changed to new NIC ID. The license does not match the current NIC ID.
Resolution
To workaround this problem, you need to regenerate the license using new NIC ID then update the environment variable method and restart the computer to get the license to operate properly.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
