Knowledge Base Article
Why does my Stratix® 10 FPGA device hang when triggering FPGA reconfiguration via nCONFIG pin and Frequency Tamper Detection feature is enabled?
Description
In Quartus® Prime Pro Edition Software version 25.1 and earlier, an issue occurs when the physical anti‑tamper feature is enabled using the Frequency Tamper Detection method in combination with an Active Serial configuration scheme. If you initiate a device reconfiguration by pulsing the nCONFIG pin, the Stratix® 10 FPGA may hang and fail to proceed with the reconfiguration process.
Resolution
You can recover the device by performing a power cycle.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
Updated 4 months ago
Version 8.0No CommentsBe the first to comment
