Knowledge Base Article
Why does my F-Tile Ethernet Intel® FPGA Hard IP Design Example fail to pass the Quartus® Support-Logic Generation phase when using either the 200GE-8 with PTP  or the 100GE-4 with PTP variants with FGT PMA?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 21.2, the F-Tile Ethernet Intel® FPGA Hard IP Design Example will fail to pass the Quartus® Support-Logic Generation phase with “Error (21842): Solver failed to find a solution”.
This error is encountered when using either the 200GE-8 with PTP or the 100GE-4 with PTP variants with FGT PMA and no location constraints applied.
Resolution
To work around this problem for the 200GE-8 with PTP variant, make pin assignments via .qsf settings which select FGT Quads 2 and 3. For the 100GE-4 with PTP variant, make pin assignments via .qsf settings which selects FGT Quad 0.
This problem has been fixed starting in version 22.2 of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
