Knowledge Base Article
Why does my F-tile Ethernet Intel® FPGA Hard IP design example simulation fail using the Questa*-Intel® FPGA Edition simulator?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.2, 22.3, and 22.4, you might see the F-tile Ethernet Intel® FPGA Hard IP design example simulation gets stuck at the reset sequence using the Questa*-Intel® FPGA Edition simulator.
Resolution
There is no workaround. You can use other simulators to run the simulation. For example, ModelSim* SE or QuestaSim*.
This problem is fixed in version 23.1 of Intel® Quartus® Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
