Knowledge Base Article
Why does Linux fail to configure the FPGA with error "arm-smmu-v3 16000000.iommu: event 0x10 received" on Agilex® 5 FPGA production silicon?
Description
This error might be seen in the Quartus® Prime Pro Edition Software version 25.1 when using HPS-first boot and configuring the FPGA from Linux, on an Agilex® 5 FPGA device with production silicon (revision B0 or later). This error prevents the FPGA configuration from completing successfully. The failure is because the embedded software provided with version 25.1 is not compatible with Agilex 5 FPGA production silicon. An example of log output showing this issue as as follows:
[ 6.060661] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 6.067061] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 6.072635] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 6.078226] arm-smmu-v3 16000000.iommu: 0x000000009ff80000
[ 6.083790] arm-smmu-v3 16000000.iommu: 0x0000000000000000
[ 6.089350] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 6.095004] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 6.100565] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 6.106130] arm-smmu-v3 16000000.iommu: 0x000000009ff80080
[ 6.111690] arm-smmu-v3 16000000.iommu: 0x0000000000000000
[ 6.117258] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 6.122908] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 6.128471] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 6.134030] arm-smmu-v3 16000000.iommu: 0x000000009ff80100
[ 6.139594] arm-smmu-v3 16000000.iommu: 0x0000000000000000
[ 6.145154] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 6.150803] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 6.156362] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 6.161924] arm-smmu-v3 16000000.iommu: 0x000000009ff80180
[ 6.167490] arm-smmu-v3 16000000.iommu: 0x0000000000000000
[ 6.173049] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 6.178700] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 6.184259] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 6.189825] arm-smmu-v3 16000000.iommu: 0x000000009ff80200
[ 6.195390] arm-smmu-v3 16000000.iommu: 0x0000000000000000
[ 6.200950] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 6.206595] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 6.212154] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 6.217712] arm-smmu-v3 16000000.iommu: 0x000000009ff80280
[ 6.223270] arm-smmu-v3 16000000.iommu: 0x0000000000000000
[ 6.228828] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 6.234473] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 6.240031] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 6.245589] arm-smmu-v3 16000000.iommu: 0x000000009ff80300
[ 6.251154] arm-smmu-v3 16000000.iommu: 0x0000000000000000
[ 6.256713] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 6.262359] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 6.267917] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 6.273475] arm-smmu-v3 16000000.iommu: 0x000000009ff80380
[ 6.279033] arm-smmu-v3 16000000.iommu: 0x0000000000000000
[ 6.284591] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 6.290236] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 6.295794] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 6.301353] arm-smmu-v3 16000000.iommu: 0x000000009ff80400
[ 6.306917] arm-smmu-v3 16000000.iommu: 0x0000000000000000
[ 6.312476] arm-smmu-v3 16000000.iommu: event 0x10 received:
[ 6.318121] arm-smmu-v3 16000000.iommu: 0x0000000a00000010
[ 6.323680] arm-smmu-v3 16000000.iommu: 0x0000020a00000000
[ 6.329238] arm-smmu-v3 16000000.iommu: 0x000000009ff80480
[ 6.334797] arm-smmu-v3 16000000.iommu: 0x0000000000000000
[ 11.494089] Stratix10 SoC FPGA manager firmware:svc:fpga-mgr: timeout waiting for svc layer buffers
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 25.1 and associated embedded software, follow these steps:
1. In the Arm Trusted Firmware source code, edit or patch file
plat/intel/soc/agilex5/include/agilex5_system_manager.h
2. Change the line of the source file that reads:
#define A5F4_JTAG_ID 0x4000F000
to the following:
#define A5F4_JTAG_ID 0x4000C000
3. Rebuild and deploy the resulting software.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 25.3.1 and associated embedded software.
