Knowledge Base Article
Why does HPS SPI controller fail to support continuous data transfer?
Description
Due to a known limitation, HPS SPI controller can not support continuous data transfer.
- When the HPS SPI controller acts as an SPI primary and transfers more than one frame, it always toggles SSx_N between each frame; it can not make SSx_N stay low during the transmitting period.
- When the HPS SPI controller acts as an SPI secondary and receives more than one frame, the paired SPI primary must toggle SS_N between each frame. Otherwise, only the first frame would be handled by the HPS SPI secondary.
Resolution
When the HPS SPI controller works as a primary, and the paired SPI secondary requires the SS_N to keep low during the transfer, a HPS GPIO can be used as SS_N instead of the SPI controller's SS_N. The HPS GPIO software can make the GPIO stay low during the whole transfer period.
When the HPS SPI controller works as a secondary, the paired SPI primary must transfer the frames one by one with SS_N toggling between each frame.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
