Knowledge Base Article
Why does generating an HDMI IP Design Example fail when selecting "No Daughter Card" in the Quartus® Prime Pro?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 26.1.1, generating an F-Tile HDMI FPGA IP design example encounters an error under the following configurations:
  • Daughter Card parameter set to "No Daughter Card" with No Development Kit selected.
  • Daughter Card parameter set to "No Daughter Card" with a Development Kit selected.
Symptoms & Affected Components:
Failure: Design Example generation fails or produces an error in Platform Designer
Affected IP: F-Tile HDMI FPGA IP (ip.Video Connectivity.HDMI)
Target Device / Architecture: Agilex® 7 / F-Tile devices
Cause:
The F-Tile HDMI IP design example generation script relies on a selected daughter card definition to automatically generate required board topology, clocking, and transceiver constraints. Selecting "No Daughter Card" causes error in the generation script in the Quartus Prime Pro Edition software version 26.1.1.
Resolution
To work around this problem, follow the steps below.
  1. Open the F-Tile HDMI FPGA IP parameter editor.
  2. Under the Design Example tab, select a supported HDMI Daughter Card option instead of "No Daughter Card".
  3. Generate the design example.
If targeting a custom board, manually update the generated top-level pin locations and clock/transceiver settings in your project to match your custom board requirements.
Patches are available to fix this problem for the Quartus Prime Pro Edition Software version 26.1.1 versions. 
Download and install patch below.
  • Quartus Prime Pro Edition Software v26.1.1 Patch 1.25
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 13 hours ago
Version 2.0
