Knowledge Base Article
Why does FPGA core configuration fail in HPS early IO release mode of Arria® 10 SoC device?
Description
In Arria® 10 SoC device HPS early IO release mode, you may see FPGA core configuration failure when you use the following command to generate core rbf.
quartus_cpf --convert --hps -o bitstream_compression=off <sof_file> <rbf_file>
This problem occurs because uncompressed core rbf file may be too large to cause configuration failure.
Resolution
To work around this problem, please use the following command to generate rbf files.
quartus_cpf --convert --hps -o bitstream_compression=on <sof_file> <rbf_file>
Updated 6 months ago
Version 2.0
