Knowledge Base Article
Why does Configuration via Protocol (CvP) fail when using CvP driver 6.6.51-lts on Agilex™ 5 FPGA and Agilex™ 7 FPGA devices?
Description
In the CvP driver 6.6.51-lts, the CvP fails on Agilex™ 5 FPGA and Agilex™ 7 FPGA devices with "No such file or directory" error in the fpga_manager directory because the driver does not create the fpga_manager debugfs.
Resolution
A patch is available to fix this problem for the CvP driver 6.6.51-lts. Download the patch from the following link and install it using "git am <filename>.patch".
socfpga-6.6.51-lts-01.patch
This problem is fixed starting with the Linux CvP driver version 6.12.11-lts.
Updated 8 months ago
Version 3.0
