Knowledge Base Article
Why does configuration occasionally fail on Agilex® 7 FPGA devices, leaving the device stuck in the CONFIG state when using a JIC file generated with Quartus® Prime Pro Edition version 23.2 or later?
Description
You may encounter intermittent configuration failures on the Agilex® 7 FPGA device, when using JIC file generated with Quartus® Prime Pro Edition software version 23.2 and later. When the issues occurs, the device remain in the CONFIG state, while both the conf_done and init_done is remain low. In addition, no error location and error info as shown below.
Resolution
To work around this issues:
- Power cycle the board or toggle nCONFIG to reconfigure the FPGA.
Patches are also available to fix this problem for the following Quartus Prime Pro Versions:
- 23.2
- 23.3
This problem is fixed starting from Quartus Prime Pro Edition Version 25.1.1 and later.
Additional Information
Note:
- If you can tolerate occasional errors that are unlikely to recur after reconfiguration, no further action is necessary.
- If you require zero-error tolerance—even for rare occurrences that may be resolved through reconfiguration or toggling nCONFIG—a patch request is recommended.
- This fix does not require recompilation of the design. You only need to reconvert the .sof file to .jic.
Add any additional information on the topic.
Related Articles
Updated 3 months ago
