Knowledge Base Article
Why does configuration fail intermittently when using a JIC file generated with Quartus® Prime Pro Edition version 23.2 and later on Agilex™ 7 FPGA devices, resulting in Major Error Code 0x0000F004 and Minor Error Code 0x00000001?
Description
You may encounter the following errors during configuration using a JIC file generated with Quartus® Prime Pro Edition software version 23.2 and later, targeting Agilex™ 7 FPGA devices with P-tile and/or E-tile:
Major Error Code: 0x0000F004
Minor Error Code: 0x00000001
This issue affects Agilex™ 7 FPGA devices with P-tile and/or E-tile during configuration.
Resolution
To work around this issue:
Power cycle the board or toggle nCONFIG to reconfigure the FPGA.
Patches are also available to fix this problem for the following Quartus® Prime Pro versions:
- 23.2
- 23.3
- 24.3.1
- 25.1
This problem is fixed starting from Quartus® Prime Pro Edition version 25.1.1 and later.
Related Articles
Note:
- If you can tolerate occasional errors that are unlikely to recur after reconfiguration, no further action is necessary.
- If you require zero-error tolerance—even for rare occurrences that may be resolved through reconfiguration or toggling nCONFIG—a patch request is recommended.
- This fix does not require recompilation of the design. You only need to reconvert the .sof file to .jic.
Updated 8 months ago
Version 3.0No CommentsBe the first to comment
