Knowledge Base Article
Why does Auto Upgrade fail for the Clock Control IP?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1, Auto Upgrade might fail for the Clock Control IP when the IP was originally generated for a Stratix® 10 FPGA device and is being regenerated for an Agilex® FPGA device.
Resolution
To work around this problem, if you are converting a design containing the Clock Control IP from a Stratix® 10 FPGA device to an Agilex® FPGA device, perform one of the following actions:
  • Convert the design from Stratix® 10 FPGA to Agilex® FPGA using the Quartus® Prime Pro Edition software version 24.3 or earlier. After the IP has been successfully regenerated for Agilex® FPGA, you may upgrade it to version 25.1.
  • Remove the Stratix® 10 FPGA version Clock Control IP and manually re-create it using the Agilex® FPGA Clock Control IP (this option is the most recommended if you use an Agilex® 3 FPGA device).
This problem is scheduled to be fixed in a future release of the Quartus® Prime Pro Edition software.
Updated 4 months ago
Version 5.0
