Knowledge Base Article
Why does Arria® 10 HPS IP generation fail with missing mgc_common_axi.sv in Quartus® Prime Pro 24.1/24.2?
Description
Due to a problem in the Quartus® Prime Pro Edition Software versions 24.1 and 24.2, Arria® 10 HPS IP generation may fail with an error similar to:
Error: add_fileset_file: no such file .../ip/altera/mentor_vip_ae/axi3/bfm/mgc_common_axi.sv
This occurs because AXI3 Mentor Graphics BFM collateral was removed starting in Quartus Prime Pro 24.1, while the Arria 10 HPS generation flow still referenced the removed AXI3 BFM file.
Associated Quartus Suite bug: QS-569165.
Resolution
To resolve this issue, upgrade to Quartus Prime Pro Edition Software version 24.3, regenerate the Platform Designer system/IP output files, and rerun compilation.
Updated 5 months ago
Version 2.0
