Knowledge Base Article
Why does a compilation error happen when using the IOPLL in the HVIO bank in place of a GTS System PLL for the PMA/FEC Direct PHY IP and all other protocol IPs for the Agilex® 3 FPGA and Agilex® 5 FPGA designs?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.1 and earlier, you may see a compilation error when using the IOPLL in the HVIO bank in place of a GTS System PLL for the PMA/FEC Direct PHY IP and all other protocol IPs for the Agilex® 3 FPGA and Agilex® 5 FPGA designs.
The error message and critical warning below are displayed
“ERROR: Argument <node_object> is an object filter that matches no objects. Specify one matches only one object.” -
“Read_sdc failed due to errors in the SDC file”.
Resolution
There is no workaround currently for this problem. The System PLL must be used for the IPs requiring it. This means that for single GTS Transceiver bank devices, PCIe* and non-PCIe protocols cannot be used together in a design.
This problem is fixed beginning with the Quartus Prime Pro Edition software version 25.1.1.
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
