Knowledge Base Article
Why does 25G Ethernet IP's dynamic generated example design fail timing in Intel® Stratix®10 FPGA ES1 and ES2 devices?
Description
Due to a problem in Intel® Quartus® Prime Pro Edition Software version 18.0, the 25G Ethernet IP's dynamic generated example design may fail timing closure.
The affected variants are as below:
- 25G with IEEE 1588 Example Design
- 10G/25G with IEEE 1588 Example Design
- 25G with IEEE 1588 Example Design and RSFEC
- 10G/25G with IEEE 1588 Example Design and RSFEC
Resolution
Launch Design Space Explorer II and perform seed sweep to get the best quality of fitter placement as the Intel® Stratix® 10 FPGA timing model is still at the preliminary stage pending engineering characterization.
Updated 3 months ago
