Knowledge Base Article
Why do the Resource Utilization results remain the same for the Agilex® 3 GTS JESD204B IP Core with either ECC_EN On or Off?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1, you may observe the resource utilization results remain the same in Agilex® 3 GTS JESD204B IP core with either ECC_EN On or Off
Resolution
This problem is fixed beginning with the Quartus® Prime Pro Edition version 25.1.1.
Updated 5 months ago
Version 4.0No CommentsBe the first to comment
