Knowledge Base Article
Why do multiple pulses occur on flr_received signals when host do function level reset to an endpoint device of Scalable Switch IP for PCI Express*?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 24.1 and later, you may see multiple pulses on flr_received signal of Scalable Switch IP in FLR operation.
Resolution
To work around this problem, you should respond to flr_completed signal for each pulse on flr_received.
This problem is scheduled to be fixed in a future release of the Quartus Prime Pro Edition software.
Updated 6 months ago
Version 2.0
