Knowledge Base Article
Why do I see Unconstrained Output Ports at the EMIF unused pins when compiling the Agilex® 7 FPGA M-Series EMIF IP?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1 or earlier, you may see Unconstrained Output Ports at EMIF unused pins when compiling the Agilex® 7 FPGA M-Series EMIF IP.
Example unconstrained output ports:
emif_io96b_<IP Instantiation>_0|emif_io96b_<IP Instantiation>_inst|arch_emif_<string>|wrapper_bufs_mem|g_UNUSED[*].pad
Resolution
You can safely ignore these unconstrained warnings.
This problem is fixed beginning with the Quartus® Prime Pro Edition Software version 25.1.1.
Updated 4 months ago
Version 4.0
