Knowledge Base Article
Why do I see timing violations between the F-Tile Dynamic Reconfiguration Suite IP and the F-Tile Avalon-Streaming IP for PCI Express* when using Quartus® Prime Pro Edition version 25.3 and earlier on Agilex® 7 FPGA devices?
Description
When using Quartus® Prime Pro Edition software version 25.3 and earlier on Agilex® 7 FPGA devices, you might see timing violations between the F-Tile Dynamic Reconfiguration Suite IP and the F-Tile Avalon-Streaming IP for PCI Express* if the F-Tile Avalon-Streaming IP for PCI Express is instantiated inside a VHDL generate statement. This leads to incorrect timing assignments, which may be ignored.
Resolution
To work around this problem, you can instantiate the F-Tile Avalon-Streaming IP for PCI Express outside of any VHDL generate construct.
This problem may be fixed in a future version of the Quartus® Prime Pro Edition software.
Updated 8 months ago
