Knowledge Base Article
Why do I see the wrong IP parameter in Agilex™ 5 FPGA E-Series GTS HDMI IP file after generation from GUI?
Description
You may see wrong ipxact parameter (PIXELS_PER_CLOCK/HDMI21_VARIANT) in IP file
Resolution
Workaround is to open the IP file by text editor and change the ipxact parameter (PIXELS_PER_CLOCK/HDMI21_VARIANT) as attached file and generate the IP again.
Updated 1 month ago
