Knowledge Base Article
Why do I see the HPS on Agilex™ SoC devices fail to boot, or observe some unexpected functional failures at run time?
Description
Due to a problem in the device manager firmware, you might fail to read/write certain RAMs on some Agilex™ AC.
You might observe the following HPS boot failures:
- HPS hangs at dcache memory write and read after executing the dcache_enable function in FSBL
- UART printout stops after “DDR: 8192 MiB”
- UART printout stops after “Loading Environment from MMC… ***”
- UART printout stops after “Verifying Hash Integrity … crc32”
- Various unexpected functional failures depending on the faulty RAM location
Resolution
To resolve this problem, update to the latest device manager firmware for the Quartus® Prime Pro Edition Software v21.2, 21.3, 21.4, 22.1, and 22.2.
The latest device manager firmware is available from the following link:
What is the latest device firmware for Agilex™ FPGA and Stratix® 10 FPGA devices?
This problem is fixed beginning with version 22.4 of the Quartus® Prime Pro Edition software.
Updated 8 months ago
Version 4.0No CommentsBe the first to comment
