Knowledge Base Article
Why do I see the following message during 100G Interlaken Intel® FPGA IP and 50G Interlaken Intel® FPGA IP generation? Warning: management_interface: Agent with readdatavalid must use waitrequest.
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 23.1, you might see the following warning message while generating the following IPs:
100G Interlaken Intel® FPGA IP :
Warning: ilk.ilk_core_0.management_interface: Agent with readdatavalid must use waitrequest.
50G Interlaken Intel® FPGA IP :
Warning: ilk.ilk_core_50g_0.management_interface: Agent with readdatavalid must use waitrequest.
It is safe to ignore this message.
Resolution
No workaround is required. It is not impacting functionality.
This problem will be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 1 month ago
Version 2.0
