Knowledge Base Article
Why do I see the ERROR: IOSSM: inline_ecc_bist_mem_init: Timeout init memory on IO96B_0 error message during the ATF to Linux* Direct flow in Agilex® 5 FPGA device using LPDDR memory with in-line ECC enabled?
Description
Due to a problem in the calculation of a timeout value in the inline_ecc_bist_mem_init() function in Arm Trusted Firmware (ATF) during the ATF to Linux* Direct boot flow in Agilex® 5 FPGA devices, the following error messages may appear during LPDDR memory bring-up when in-line ECC is enabled:
ERROR: IOSSM: inline_ecc_bist_mem_init: Timeout init memory on IO96B_0 ERROR: IOSSM: inline_ecc_bist_mem_init: BIST_MEM_INIT_STATUS raw status = 0x0
These error messages appear when an incorrectly calculated timeout value expires. This problem may be observed in any boot flow where ATF BL2 is used as the first-stage bootloader and is present in the Quartus Prime Pro Edition releases 25.1.1 and earlier.
Resolution
To work around this problem, implement the following calculation for the timeout (stored in the variable read_count) in the inline_ecc_bist_mem_init() function located in plat/intel/soc/agilex5/soc/agilex5_iossm_mailbox.c:
read_count = TIMEOUT / read_interval_ms;
The problem has been fixed starting with Quartus Prime Pro Edition software version 25.3. U-Boot boot flow is not affected.
Updated 4 months ago
Version 5.0
