Knowledge Base Article
Why do I see Support-Logic Generation error when implementing the F-Tile Ethernet Intel® FPGA Hard IP with '50GE-2', 'MII PCS only' and 'None" FEC mode options selected ?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.1, you may see a Support-Logic Generation error when implementing F-Tile Ethernet Intel FPGA Hard IP with '50GE-2', 'MII PCS only' and 'None" FEC mode options selected.
The Intel® Quartus® Prime Pro Edition Software versions 21.4 and earlier are not affected.
Resolution
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.2.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
