Knowledge Base Article
Why do I see PLL locking issues and data errors when I use the 100 MHz FPGA input clock (fpga_clk_100) in the Intel® Stratix® 10 SoC Golden Hardware Reference Design (GHRD)?
Description
The FPGA 100 MHz clock fpga_clk_100 on PIN_AW10 is incorrectly defined as a LVDS clock in the Intel® Stratix® 10 SoC Golden Hardware Reference Design (GHRD) version 18.1 and earlier. This can cause unexpected behaviour in the design for logic clocked from this source.
Resolution
To resolve this problem, edit the IO assignment for fpga_clk_100 from LVDS to 1.8V (PIN_AW10) using the Assignment->Assignment Editor or Assignments->Pin Planner tools.
Note: If the design has been compiled the IO standard on the auto created LVDS complement signal fpga_clk_100(n) must be set to 1.8V. The auto-created LVDS complement signal will then be removed automatically.
This fix is scheduled to be included in a future version of the Intel Stratix 10 SoC GHRD.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
