Knowledge Base Article
Why do I see incorrect audio frequency output from the HDMI Intel® FPGA IP RX core when fixed rate link(FRL) mode is enabled?
Description
Due to a problem with the HDMI Intel® FPGA IP RX core, audio output is broken when FRL mode is enabled.
The internal audio clock is incorrectly recovered from the link clock based on the received number of pixels per clock(N) and CTS values in FRL mode.
The audio works correctly in Transition Minimized Differential Signaling(TMDS) mode.
Resolution
There is no work around for this problem in FRL mode. If possible use TMDS mode.
This problem has been fixed in the Intel® Quartus® Prime Pro Edition software versions 20.1.
Updated 11 months ago
Version 3.0
