Knowledge Base Article
Why do I see generation error message when generating F-Tile Multi Channel DMA IP for PCI Express* Example Design using Quartus® Prime Pro Edition software version 24.1 for Windows*?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 24.1 and onwards for Windows, you may see the below error message when generating F-Tile Multi Channel DMA IP for PCI Express* Example Design.
"file delete -force -- "${ORI_TEMP_PATH}/pcie_ed_rp/pcie.qsf""
    (procedure "::intel_pcie_ftile_mcdma::generate_design_example_files" line 230)
    invoked from within
"::intel_pcie_ftile_mcdma::generate_design_example_files  ${QSYSTemPath} ${QSYSTemName} $TEMPPATH"
    (procedure "::intel_pcie_ftile_mcdma::generate_dynamic_qsys" line 1819)
    invoked from within
    (procedure "::intel_pcie_ftile_mcdma::dynamic_example_design" line 10)
    invoked from within
    (procedure "::intel_pcie_ftile_mcdma::fileset::callback_example_design" line 2)
    invoked from within
"::intel_pcie_ftile_mcdma::fileset::callback_example_design intel_pcie_ftile_mcdma_0_example_design"
Error: Failed to generate example design example_design to: C:\altera_pro\24.1\quartus\bin64\intel_pcie_ftile_mcdma_0_example_design
Resolution
To resolve this problem, use one of the following methods:
  1. Perform the design example generation step in a Linux* environment.
  2. Use Quartus Prime Pro Edition software version 25.3. During the design example generation, disable the “Simulation” option in the IP GUI.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 26.1.
Updated 4 months ago
Version 5.0
