Knowledge Base Article
Why do I see "Error(18108): Can't place multiple pins assigned to pin location" in my design with Partial Reconfiguration?
Description
In projects with Partial Reconfiguration (PR) enabled, you might encounter the error message "Error(18108): Can't place multiple pins assigned to pin location" when you use the device AVST pins as dual-purpose mode.
Resolution
When you use PR External Host, the AVST pins are reserved for configuration and reconfiguration purposes; they are not available for dual purposes. Re-assign your pin locations to avoid this error.
The AVST pins as dual-purpose are accessible when you use PR Internal Host. To avoid this error, include the following assignment in your Quartus® Settings File (.qsf):
set_global_assignment -name FORCE_AVST_DUAL_MODE_PINS_FOR_PR ON
The assignment is available starting in the Quartus® Prime Pro Edition Software version 24.1.
Updated 11 months ago
Version 3.0
